fury1
got a new to me 2005 gasser 200,took out the carb to see what jetting it had,couldnt make out anything on the needle,I assume its stock,it had a 180 main and 40 for jets ?does that sound right,havent started it yet,just sorting some things out,needs a pipe and the kicker ratchet stuff replaced like my 300 needs to have fixed also
also looked like the float was way too low when you turned the carb upside down wasnt even close to parallel like im pretty sure its supposed to be,also had a br7e plug,I put in a br8eg which I think is stock,havent been on a 200 in a while,put my 06 yellow plastic on it to spruce it up a little,has the dual map ignition and the wires are connected(not sure what setting that is)
