Since I already have this thread going, I wanted to continue in the evolution of my GasGas: Maybe this should be in the suspension section, but I'll keep it here for now.
I wanted to keep the GasGas wheel (2010) since I had spare wheels and the GasGas front brake caliper. The YZ Axle is 20mm, my GasGas Axle was 25mm. I used 20mm bearings from an older GasGas and made a spacer... I'll probably make a one piece spacer when I get some lathe time.
Parts Used:
$12.99 1996-2003 GasGas Front Wheel Bearing and spacer kit
$56.00 Braking 260mm Caliper - Bracket Part Number POW106
$260 2007 YZ250F Front Forks (Valved for woods already by Factory Connection) and Axle
$74 2005 YZ250F Triple Clamps (Billet upper triple made by Applied)
$27 MSR Fork Seals and Wipers
$26 All Balls Steering Stem Bearing Kit 22-1001
---- Rear 20mm wheel spacer and a 3mm shaved down 20mm spacer
Excellent work.
I've seen several Gassers that have been equipped with the Yamaha forks. Yours is the first that I've seen that kept the GasGas front wheel with the swap.
What spacer did you use on the front wheel? Did it come with the front wheel bearing kit, or is that the Tusk package?
What rear wheel spacer (supplier/brand & model?) did you use?
I'm always looking for parts sources and crossovers.
Thanks in advance, and Good Riding!
I also used the Gasgas wheel in Kyb forks. I turned suitable spacers on my lathe and kept the 25mm ID bearings. I made a 250mm brake disk (keeping the Gasgas caliper) instead of using an adapter to move the caliper outwards.Here's another thread (mine) using the GG wheel & brake with the KYB forks.
http://www.gasgasrider.org/forum/showthread.php?t=14592
I used a rear wheel spacer from an older gasgas that had the 20mm axle and added a 3mm shim that I created by grinding down another wheel spacer. You could use an older gasgas 20mm front wheel spacer and add a 6mm spacer.
If I recall, the distance between the forks was 131mm. I placed wheel in the forks and had the rotor clamped inside the caliper. With the seals removed, I took measurements.
On my setup the front wheel is centered between the forks.
Nice work!
