The Angry Chook
I've had the bike for about three years and it runs well but uses a lot of fuel. It loads up in the tighter stuff at about idle to 1/3 throttle and takes a bit to clear out when the tracks open up. It also has a bit of a hesitation and doesn't pull cleanly right through onto the pipe.
Im looking to clear it up and make it more snappy as it seems to be running very rich.
Current is 180 main, 40 pilot and N1EF on the second from top clip.
Temp is from 10-25 C at under 1000f
I've got a N3EJ needle after a mate recommended it but he had a 2009 and I don't know which carb he had. I have the AS1 38mm (Screw cap).
I've ordered a 38 pilot and 178 main to play with but from reading I may need a 42 and 175 as well.
Can anyone tell me how much leaner (or richer) the N3EJ is than the N1EF?
Any advice from others with similar specs or problems with fuel?
