Hi, Up for sale is my Gas Gas 300 which I bought from Sandiford Off Road a year and a half ago. I've used it for hare and hounds meetings. Its the XC version which was specifically designed for the UK market that doesn't have the homologated parts and can still be road registered if required.
The bike has been genuinely maintained to the highest standard with many extra parts and mods as listed below. I'm an engineer by trade and I'm quite anal about bike preparation, so what ever its needed, its had done. Air filter replaced every ride (rotating 3) and gear oil every other ride.
Info:
Ohlins rear shock - Serviced at start of year by Andy Dawson
Ridden once since forks recently re-valved and serviced by Pro-Action. ?305 receipt
New FMF Q-Stealth silencer
Michelin BIB Mouses F&R
Biketech large volume power valve cover (Improves low end torque)
New chain & sprockets - Renthal R1 O ring chain
Wossner piston kit fitted approx 15 hours ago
New Gas Gas front pipe
Alloy Gas Gas sump guard
Acerbis hand guards
Head stock bearings recently replaced
Linkage and swingarm bearings good and recently re-greased
Power valve set correctly
Carburation extensively worked on with a different needle, pilot and main jet. Its now perfect, clean right from the bottom end to the top and smooth.
Renthal Kevlar Dual grips
Comes with:
Matching spare wheels, Red/Black with tyres, discs and sprocket. (Front has new Racing disc)
Spare front pipe and end can
Gear lever
air filters x 2
A selection of sprockets
New front brake pads x 3
New Rear brake pads x 2
New Front wheel bearing kit
New Rear wheel bearing kit
I was planning on keeping it, but have had an offer on a new one which is too good to turn down. Will be sad to see it go. I would like to sell it all together as a complete package, its ideal for someone wanting to compete or just go laning.
?3150 ovno
Sam 07970061496
Info:
Acerbis hand guards
Comes with:
Gear lever
air filters x 2
?3150 ovno
Sam 07970061496
