REBOUND
I have found the rebound in the Ohlins rear in my EC300 likes being set at 20 out. It is a little bit quick, but when I wind it but 2 or 3 more in make it very slow and packs down over rough ground.
Pulling the shock apart and removing the 2 cross over shims lets me run the rebound out a little further and makes each clicker adjustment a bit more progressive.
COMPRESSION
The low speed compression at 16 out is good, but I run the high speed nearly all the way out as it is way to hard hitting logs, square edge rocks, etc. I have dropped a 3 or 4 of the largest compression shims to soften the whole stack up.
I havent tested the compression side yet, so I will post up once I have ridden it. Anyone else played with these?
COMPRESSION
