Please feel free to add comments or advice.
Here is the leak tester that I put together today. It cost about $25.00 total and it worked really weli. This is what I did on my bike. Make sure that you pressure test the tool before you attach it to the engine. Set your engine at BDC, block off your intake, exhaust and powervalve vents. Use a handpump and don't go beyond 5 PSI because after you stop pumping the pressure can still climb about 1 PSI. Any more than 6 PSI can blow out your main seals.
When I attached the gauge to my engine the engine held 6 PSI for 15 minutes with almost no loss( about 1/10 of 1 PSI ). I completed three tests with the same results. So, my engine should be solid after this rebuild.
Here is the 1.5 inch mechanical pipe plug for the exhaust.
Here is the 1.5 inch mechanical pipe plug for the intake,
I think your test set up is going to test for (and hopefully not create) leaking gaskets and crank seals. Most leak down detectors used to evaluate ring and valve seal use two guages so you can compare incoming air hose pressure against cylinder pressure at TDC. The percentage difference is supposed to be the leakdown percentage for that cylinder. You typically run the leak down test with open intake and exhaust to allow leakage to occure so you can meaure it.
sorry no
Sorry, I don't have clue re the clip/spring.
Your leakdown tester looks good to me.
Great job on the whole thread . Thanks for posting it. I know it was time consuming for you.
Here's a Gas Gas noob question for you. What's the best (or correct) way to bleed the cooling system? Or, will it bleed it's self? I'm just finishing up a top end job on a '01 XC 200 and could use some input on that.
Thx again.
RB
