GMP
Active member
Are you refering to me? This is the northeast, its a very rare day when the bike comes home clean enough not to require a bath and service.
What I found to be the biggest problem is if you remove the tank for an extended period, say a week, then it is VERY hard to deal with. This is exagerated if the cap is left on and the tank is on its side, where the check ball can close the vent and the tank builds pressure from redidual fuel. When first removed you would never think there was a problem as it fits quite well, and refits fine immediately thereafter. Even now there is no obvious distortion with it installed and the plastic and seat all fit fine. I wonder if it expands to a point and then stops? I'll try and refit it again as a test after an extended storage and find out.
