2017 EC 300 vs 2008
Talked to few dealers.
Since '15 there should be no known issues in the starter mechanism.
First kick from cold always start it by kick, then use button.
A few button starts in close proximity, and battery is drained. Only relay or plunger could be heard... tk tk
Next day measured 12.5V, connected it, got topped in 1/2hr, left overnight.
Now measures 13,0 few hrs after trickling.
It's no problem, if battery is to blame, but fear a sticking starter.
After you ride that bike your plans will change. You will find the 50t sprocket unnecessary. I ran a 50t on my older GG bikes but on the 15 I stuck with the 48. Also the stock exhaust works very well and the 17 will ha e what seems like 2x the power of the older bikes. Once you get a taste of the e-start there's no way you will take it off. Just spend $75 on a lithium battery and throw the kicker in the trash bin. Lol
Now considering li ion, dealer said it is useless addon in tad over and below freezing temperatures.
Presume that if bike stored in warm garage, and while riding in freezing temp, its being charged, should be ok.
Maybe frequent start stops take its toll, if riding in low temps.
The trick with a Li-ion battery in cold temps is they need to "warm up". It only takes a minute at most. If you try to use the button right off the truck when it's cold chances are you will think your battery is dead. With mine I usually just turn the headlight on while I get dressed to put a load on the battery and then she will crank right over when the time comes. KTM even has some sort of procedure in their owners manuals now since they have switched to Li batteries.
+1
common sense, why push the battery with cold start when you don't really need it then
Spoke tu eastern EU dealer, he advised to always kick the bike when cold, then button it.
Something about longevity of the starting system.
So li ion all the way!
Key switch is already wired so that light is always on.
The newer small starter is the same as a KTM, they are ok but I would consider it a re starter, not ideal for using all the time it wont last.
My thoughts also.
Untill they get it as integral part of the engine, and give it more direct gearing, they are more prone to breaking.
I really like the suspension in the woods. Plush yet firm, but Is there a tool available for the PFP preload adjustment?
Would really mess up thin anodizing with pliers.
Also, stock chain seems too short.
Already had to loosen it a bit to get that min 3cm clearance, but tyre is now too close to shock protector and rubbing it away.
Its that overstretch sound when 50% or more wheel travel is reached.
112 continuous chain, no connecting link.
Differences between 2009 and 2011?
The updates from 09 to 11 were mainly cosmetic I think. The 11 has the red B profile tubing in the frame while the 09 used the black rectangular section tubing. Plastic and detalj are also different. As far as I know, the frame geometry didn't change. If there are differences engine wise, they are not significant. Perhaps the biggest difference is what type of suspension the bike has, but that depends on more than the model year.
Take a lok at the Gasgas website, it has both pictures and data of previous models
Sent fra min E5603 via Tapatalk
Of course you want an 18. Why buy a 17 at this point? They have been same bike for years. You could save money and buy a used 15 and it would be same bike...lol.
Yeah it is heavy...get the 18 no doubt.
I agree.. however the 17 is the refinement that has taken place since 2012. The 18 will be the start of something new, which could include some minor tweaks to chassis/geometry in 19+ ..however 19 is rumored to have a new engine as well. 2020 new bike :D
