2018 GP300 Crank Big Needle Bearing
VintagePhill
Hey Guys,
Does somebody know the Code and manufacturer of the lower main Crank needle bearing for a 2018 GP300?(See picture)I want to rebuild the crankshaft myself and don't need the crank and main shaft contained in the set.
If you need to rebuild a crank, you'll need a new rod, bottom pin, thrust washers, and big end bearing as found in this kit.
Not sure why you'd rebuild a crank without a rod/pin change.
If the rod and Pin are still in good shape I'd just change the bearing and be done so my thought. Are there any implications to this idea if no visible wear is present?
If I remember correctly, the rod used in the legacy GG/Rieju 250 and 300 are the same as mid 90s Honda CR 250 rods. You may be able to find a Honda part easier.
I will NEVER rebuild a lower end w/o replacing everything I can! I had a 1982 Maico 490. Had a bearing failure (don't recall which.) Around 1994 if I recall.
There was 1 bearing I couldn't get for another 2 weeks. Said F' it, put it together. Ran great for 1.5 hours and that exact bearing failed. Redid the whole thing again.
Moral, don't get that deep and get rushed and don't replace associated parts. It ain't worth it!
