2018 XC300 No Spark
Res and blue test 15.5, the other two in the 4 pin test at 99.5 like you said. The other one shows 1 ohm.
Does this mean it looks like the stator is good and it's a CDI issue?
It does to me but I had the good fortune of having one to try to confirm it. It is a known issue I?ve mounted mine on 4mm foam to help take out some vibration when you get your new one fit it and start the bike then put your fingers on the cdi the amount of vibration is unbelievable. My new one has come from Rieju.
