Ashmy19gasgas
After 9 hours bike failed to start. Just heated back from dealer that the woodruff key has sheared off. All will be sorted on warranty but it?s still wank however you look at it
Hmmm mine has stopped and has a back fire on about 3 or so hours on it (128km) . About to compression test and check the flywheel key ....mine is a 19 also .
Hmmmm, back firing after 3 hours... intriguing... another woodruff key sheared?
Have you got a flywheel puller?
Keep us posted!
It could also just be a fouled spark plug, I would try a new plug first.
Done all that . Was fine then went to start but no go. Other than a possible sheared key the filter installed by the factory or dealer wasn?t installed correctly...bottom right corner sealing face of the filter folded back. So check your air filter when a new bike gets delivered ( no matter what make )
Yeah, any update? I'm picking up my new EC 300 from the dealer next weekend........enquiring minds gots to know![]()
Just for peace of mind, I would ask your dealer to check the torque of the flywheel nut before you collect it, it'll only take them 5 minutes, I'm sure they wouldn't mind.
Or even better, check it yourself when you get it home.
Have fun on your new bike, I'm sure you'll love it!
