drewgoldsmith
I was pondering the rear tire ware rates of two strokes vs. 4 strokes. I would assume that two stroke's wear out drive tires quicker due to more wheel spin. I think four stokes by nature let the tire "grip" every other engine revolution due to the nature of four strokes. They also put out more tourque, and HP so someting has to oppose the force of acceration, and that has to be the tire. With this is mind do 2k3 ignitions in the rain setting use up tires slower then say the yz 250 that I ride? I could see ignition mapping playing more or a role then 2k2, 2k3, vs. yamaha ignition. Flyswheel mass would also be a factor. Not sure where I am going with this because I am a fan of 2 strokes for the woods but everything has its pro and cons. Out right tractions does not due you much good when you have to slow down a manuver around rocks fairly often trail riding compared to MX.
Thanks Drew
Thanks Drew
