Where in Scandinavia are you located? I live in Norway.
I doubt that you find a 4-pot with the same mounting holes as the OEM Nissin suitable for a 320 disk.
The GG SM bikes were delivered with an adaptor to fit "Brembo 40mm" and a Brambo 4-pot caliper.
THis is the part you need
"Brembo 40mm" is the old Brembo standard used by lots and lots of european street bikes in the nineties. E.g. any Ducati before 1998 had these calipers. Very easy to find secondhand.
The alternative would be to use this adaptor to move the OEM calipper out.
ISR, PVM, Spiegler and others make aftermarket calipers that uses Brembo 40mm fitment. If you choose to go for a 4-pot or a 6-pot, I presume your master cylinder might also need replacement, but I havn't tried running the OEM master with anything but OEM Nissin caliper.
My youngest son just built an EC300 SM, using the above mentioned adaptor and a ISR 6-pot caliper with a Brembo radial master cylinder. Works very well.
Thats what I was looking for. Brembo 40mm. Ive got an order for Morad rims, with tires, adapter and discs and sprockets, so thats allright. Just needed the info about calipper size. Yeah, I know about the master cylinder.
I live in Norway, and Ive seen your sons gasser SM
Parts are to expensive in Norway. I know GasGas in Spydeberg, and Thomas Tandberg (bought my old gasser), but they all need to order parts from Gasgas factory - and thats the problem. The factory is slow.
