Quicky1980
I have the infamous 2002 400 FSE engine and have the dreaded wont start issue.
The bike came to me like it and Im in the process of trying to sort it.
I was told by the seller that the bike can be pushed started but I have been unable to confirm as I don't have any hills near me nor a suitably grippy floor to make a good enough run at.
I've left the battery on charge with my battery tender so I'm thinking the battery is to a suitable charge. Battery age and condition isn't clear but a receipt indicates it was changed early this year.
When I use the electric start the engine turns over and I can hear the engine compressing and sometimes get a misfire/back fire but no start. I smell fuel from the exhaust and hear the fuel pump priming so I think its injecting.
I've tried kick starting it a few times but again, no luck.
I'll try and get a video up to show the engine cranking on e start.
Any ideas? I've heard that valve clearance might be a root cause, another idea was an auto decomp valve?? Never heard of this valve so could do with a bit of guidance on what this is, likelyhood of failure and where it is (how is it to fix).
Thanks ahead.
Thanks ahead.
