Arrow Pipe, Finally...
fasteddy
My stock pipe has finally started to crack and split, plus it has a couple good size dents... So I finally swapped it out with the Arrow Pipe I got last year through the group buy on the forum.. I had installed a Lectron carb a couple weeks ago and it has done wonders power delivery wise, I was a little concerned about swapping out the pipe as I did not want to lose the gains from the Lectron... Well that Arrow pipe has added a bit more to the bottom and more to the mid.. It pulls so well down low that I've put the 48 tooth rear sprocket back on..With a Rekluse, the Lectron and the Arrow pipe I'm a very happy camper..
Ed..
Wow improved bottom end and super rock clearance, that is the right combination for my kind of riding - or is that just the camera angle? It looks a lot higher and out of the way than the stock pipe
It's an Arrow pipe....and....Not the camera angle...Tonnes of clearance, pipe is on the thin side, we'll see how it holds up..
It's a Clarke tank, did some minor mods to make it fit.. Shrouds are stock gasgas, I left the pretty ones with graphics on the stock tank.. If my mileage improves with the Lectron I'll probably go back to the Stocker..
Its a lot higher than stock, but makes up volume on the rhs so hangs out some. As above.. Its thinner too. Light, but not so robust.
