I think I should just buy the Dyna Ring new looking at the feedback from 200 racers
where is the feedback you saw? i'm interested in the dyna ring, i had a rekluse on my 200, but never got it where i wanted it. with full clutch ability the dyna ring should be a homerun, but i'm still concerned about the hydraulic preload on the master cylinder...
hah, unfortunately i'm not willing to put $900The Rekluse EXP is the "homerun" you are looking for, I'm just not a 200 rider. The EXP works awesome. Instant response off idle and still have full clutch use. Rekluse also has excellent technical support.
 into a clutch.
 into a clutch.hah, unfortunately i'm not willing to put $900into a clutch.
does the only time the master cylinder pressure screw need to be adjusted is when you want to bump start? you loosen/tighten the knob to change engagement point right (in combination with the springs in the clutch)I have some friends who are using the Dynaring in their KTMs and they work very well.
