vaughn
I'm putting my bottom end back together. Some of the bearings I installed already had blue bearing grease in them (ones that I had to remove the outer seals from). This is in the trans area, not the crank.
My question is, how hard should I try to get that grease out? Will it effect my clutch plates once I am up and running?
Thanks!
Thanks!
