Another newb question regarding the shock linkage and swingarrm. I was riding in some fairly wet conditions yesterday and decided to inspect the linkage. The bike is on 01 300 just for reference. I have removed the pull rods and the shock at present. I noticed that all of the parts I removed have bushings not actual bearings. The replacment kits at gofasters mentions bearings. If this is the case can you retrofit the bushings with the bearings? If not is there anything I should be looking for with the bushings, or should I just go ahead and replace them? Thanks Carl.
