Rebuilding An Aging GasGas, Worth It???
Rebuilding the old girl
Maybe relevant. Maybe I am an idiot.
I haven't ridden much in the past 5 years. Last serious ride was the Shane Watts school in 2014 with my daughter ( a complete blast, except my bike had an intermittent ground problem, and i looked like an idiot when it would die unexpectedly (only happened at school - go figure.))
Anyway, moved to Montana. ALL of running/bicycling speed goes away. Altitude? Nope, bad heart valve. Mortality and all of that.
Anyway, kids are out of college, and i decide to start riding dirt bikes again. (My daughters were my riding buddies - riding w/o them wasn't as much fun, so college meant not much riding.)
So, what to buy? Sort of had it narrowed to a GG (new 2018 model) or a Yamaha YZ250X (read good things about it here). I was looking at new gassers, and found a "Transformation kit" for the 2002 EC 300 (gasgaspartsguy.com = Thanks Brad and Bud! ).
i ran some numbers, and checked my inventory of GG spare parts i have accumulated, and thought, "what the heck - let's try the transformation kit."
I am not a very good rider, so i don't know how much a new bike will help. So, let's try to fix the old one.
GGpartsguy ordered me one up, and it arrived about 5 weeks after the order - from Spain.
1. The good: I am not yet done with the bike as I am refreshing the suspension, but it is going to look great. (Thanks to Steve Beane at afterhours cycle and Terry at Northwest Suspension.) The kit comes with Graphics, red radiator shrouds, and white fenders. Everything is pre-stickered, but the kit comes with additional radiator shroud graphics. I thought that i would wait to install the new stickers; I will do that after i wreck those that came on it. It also came with swingarm stickers - nice.
2. The bad. This kit is a complete pain in the a$$ to install. it fought me at every turn. I mean EVERY turn. Nothing went smoothly. If you're thinking about doing this, be close to a hardware store (my 2002 hardware didn't work with the new kit), and be ready to cut parts, hack plastic, machine spacers, etc. You have to use your old airbox boot, and that turned out to consume a ton of time. The new seat doesn't fit the 2002 - i had to cut quite a bit of the base away, and the front of the seat doesn't reach as far as it should.
For instance, GG provides a headlight shell and an H-4 light, but no wiring, and no screws to assemble the parts to make it work. Luckily, i had an assortment kit of stainless steel pan-head sheet metal screws, which seem to do the trick. I had to modify the old headlight vertical adjustment to work with the new bike. It wold be worth an additional $50 to have all the nuts and bolts included. Ironically, the nuts and bolts and screws they did include didn't fit anything.
There was no place for the ignition box. I was going to make a shelf for it, but there was no room. Instead, i used some super high-strength velcro and velcroed it to the inside of the right side cover inside the airbox. Seems pretty tight - we'll see how it goes. I didn't have to lengthen any wires to do this.
The new subframe is steel, and it fits pretty well. It's heavy, but at this stage in my life, i don't care too much. Seems pretty durable. It was finished in black, which sort of contrasts with the nickel-plated frame, but that's OK. i was too lazy to repaint it.
Anyway, i really like this bike, so now that it is almost done, I am sure i'll forget the pain of assemble/fabrication. I need to wire in a H-4 bulb socket and headlight switch tomorrow, assemble the shock with new parts, and install new springs, bushings, seals and wipers in the front fork when those parts arrive (Tuesday?). I can post pictures if anyone cares (if i don't need a photo hosting service.) Oh, i also have to spoon on some new tires which are here. Yee haw.
Thanks for reading. A 17-year old dirt bike looks like a new modern bike. who would have thunk?
Thanks guys!
I will post pictures in the upcoming days. The airbox connection was a real pain, so i want to minimize the number of times i have to take the subframe on/off. Once the shock is back together, I'll install it and the subframe, then shoot some pictures. My goal is to be done with this by Saturday, then start on my Super Tenere.
More a bit later.
Haha, thanks for the input. My bike has actually been pretty easy on me as far as everything I have done to date (stator, e-start, lighting, Lectron install, seat cover, etc). It does have its quirks, and I bet a full tear down and partial rebuild will be tough.
I do spend a lot of time finding replacement hardware as it is. The bike is tough, but I have hardware that breaks nearly every hard crash... really should stop doing that :rolleyes:
Love to see some pics of the bike!
I agree the hardware part is a pain, on my 2000 the seat fit w/o out trimming just forceful placement, it now fits well after being ridden and seat adjusts to the tank shape. I mounted my CDI in the same spot the 2011 used on the inner rear fender near the air filter with a modified 2000 mount. My rear subframe was aluminum and needed some mods to the mounts so the assembly was square above the rear tire. I hope you enjoy it!
My big concern at this point is the airbox. I looked at the GG manuals, and they don't list the old-style airbox boot (the big rubber part which attaches to the back of the carb).
If i have issues fitting the 2002 airbox back to the carb, i am going to cut the rubber to the carb, then pass a silicone air tube through the rubber, machine an tube to support a UNI pod filter, then install a UNI Pod filter in the airbox. I can use black silicone hose (looks stock), and if i run a 6" long, 4" OD UNI filter, i will have ~75% of the surface area of the old style air filter, and ~100% of the new style air filter.
it's a shame that GG doesn't offer that air boot any longer - but it gives me something with which to tinker. I'm an optimist - i know that today will be better than tomorrow.
Something isn't fitting together correctly, it's fighting you too much. What I remember finding out was the 02' style boot had holes for the mounting plate/ring and the 11' style had no holes but otherwise the same. I have the 2011 boot on my bike with no mounting holes and it fits well on my 2000 EC250 with the transformation kit. I know people have drilled the 2011 airbox front panel and used the 02' style boot mounting. You should post some pics of the subframe & airbox assembly.
Thanks. You've opened pandora's box - i am going to pick your brain some more.
1. The carb - boot interface wasn't too bad. The only fitment issue i had was that the boot at the bottom of the carb only made it to about 1/2 the width of the flange on the end of the carb. I used my heat gun to stretch it a bit, and it was fine. I don't know if that will take a set (i am hoping) or i'll have to do it everytime. That boot is 19 years old (according to the manufacturing date), and it's pretty stiff.
2. I'd be happy to buy and install a new airbox boot. What I am missing is what I need to update. (I did drill the six holes in the transformattion kit - i had to because the back plate is where the threaded rod screws to secure the air filter - please see http://partsfinder.onlinemicrofiche...l.asp?Type=18&make=gasgasdb&a=75&b=5&Action=O
the 2011 boot shows holes in the fiche, but no fasteners passing through.
3. What i don't see is what i need to upgrade to the new (2011) airboot. Here's the parts diagram for the 2011: http://partsfinder.onlinemicrofiche....asp?Type=18&make=gasgasdb&a=28&b=19&Action=O
I would be happy to buy part 1, part 2, ( i have part3, 5, 9, 10), part 11. what I am unsure about is into what does part 5 go? I didn't look too closely at my part 5, but i don't know how this works w/o seeing it.
The new style air filter is MUCH smaller than the old style air filter, so I am unsure against what the air filter face fits against in the new style airbox.
Any help/advice you can offer is solicited. having a fresh airbox boot would really make me happier - the old boot seems stiff and tired.
Thanks!
blitz
Thanks!
blitz
I suppose the stiff boot would cause issues. #5 is a pin used with the spring #9 & spring seat #10 that pushes against the inner rear fender and also the filter & cage to seal the filter against to the inner lip of the boot. What is needed is #1,2,3,4,5,9 & 10. The boot just fits into the front air box panel#14 with no hardware. # 11 are push pins for the lower lip of the side panels. The fiche shows holes in the boot but it doesn't have any, the GG fiche needs some work.
Thanks. THAT makes sense. Now I understand it. If the new airboot doesn't have holes, then that would enable the air filter face to seal against the smooth rubber.
I have all of the bits i need except the airbox boot. There are no boots in the country at this point, but i am waiting for the dealer to let me know when to expect one. I'll order when they call back.
I'll upgrade this to the new boot, and then the bike will be perfecto-mundo.
THANK YOU for your time with this. VERY helpful, and it probably cements my claim that I am an idiot.
I'm glad it helped. Good luck and post some pics!
Almost done
hi Guys,
Well, the bike is almost done. Forks have new springs, seals, bushings. Shock has new spring, bushing, o-rings, teflon seal, seal head, and reservoir cap. New tires were installed, and the lights were wired (and work). New dirt tricks countershaft sprocket.
Because the old plastics were blue, i had quite a bit of blue stuff on the bike - carb air filter, hammerhead shift lever, front brake M/C perch mount, new blue G2 handguard plastics (which are 10 years old, but the old plastic worked, so i left it), crossbar pad. I think i'll just let them remain blue.
It started, rode it around the house a bit. I have to work on jetting - but that's for another day.
I don't have a image hosting account, so i uploaded what I could here.
Things to do.
1. Set rear sag. Close, but excessive. Front sag is good.
2. Wait for new airbox boot. The 19 year-old boot took a permanent set so it fits great, but that rubber is REALLY stiff. i'd like to update to the new style air filter. I have two new style air filters, two cages, and the anodized rod/spring assembly, so if i can score the boot, i'll remove the subframe, set the sag, and install the new airbox boot.
3. Change coolant and gearbox oil. Minor - i had to start another project.
So, i'll finish this up once the new airbox boot arrives.
Thanks for watching.
Almost done
One last image - parked next to the kids' EXC 200s.
looks Great, thanks for sharing! You and Bandit are inspiring me by finding parts for your older bikes. Can?t wait to get moved and dive into mine.
