brake pedal
randy
what year kawie rear brake pedal fits an 04 ec 300? i know there is slight modification,,but i was looking for the year??? thanks all
i used a 98 kx250 on a 2000 frame.. the 2000 frame is a little different at brake pedal mount. but it should be easy to make work on later frames- just bush the pedal to fit.
i think a bunch of the kx250/kx125 brake pedals are the same from that era...
Only difference is his '04 post is replacable, yours is welded to the bracket. Same OD (12mm).
more!!!!!
thanks,,maybe more direct if i ask,,,does anyone know where i could get an aftermarket brake pedal,,,,i did try the shark from T.E.D but it broke (up on a hancock ride) right at the hole for the return spring,,,other wise it was a nice pedal,,,,i looked at sunline and they have yhem for newer kxf,s but wasnt sure if they fit,,,or any alternative and feed back would be great,,,,,,,,
