Can't put on neutral gear
Getoviq95
I made full rebuild on my ec 300 and now the engine is ready ,but i can't put on neutral gear .Another gears work fine ,but won't stay on neutral .When i remove the left engine case i can put on neutral ,but when i assembly the case i can't .I'm confused ,any ideas ?I tried also with oil in tranny ,but its the same.
Shift shaft binding?
Some folks have bent their shift shaft so badly they had to cut it off the splines in order to remove the shaft.
Are you sure the shifting parts inside the right side case are assembled correctly? Check the parts for cracked welds.
I had a similar problem, but I cannot remember what exactly the problem was. If I remember correctly, there is a spring loaded arm/ roller that is supposed to keep the selector drum in place in neutral. I think my problem had something to do with that arm and its shim or washer being on the wrong side. I did write a post here about it once, but as I said, years ago.
Sent fra min E5603 via Tapatalk
Shift shaft is ok .I'm sure ,that the shifting parts inside the right side case are assembled correctly .Today i put ot neutral once or twice ,but now i can't :( .
I put it in this way .Is it correctly ?
This way.. this is the bike in neutral, with the roller sitting up on the ridge between 1st and 2nd on the selector.
Yes there is always a logic ;-)
Putting on the engine cover will put some pressure om some part because the is a misplaced shim or something similar.
Some pics ,i'm sure that the problem is here ,but what is wrong ?
ItI solved the problem ,I'm a (censored) idiot .I was change the places of roller and bushing ,now everything works fine .Thank you guys !:)
Look at the first picture in post #10. The roller is over the pins. I believe the roller needs to be on the cam part (pivot arm must be closer to the engine case).
