Sorry I meant Pin 4. I am converting a KTM CDI wire harness for use with a GG dual map CDI. The GG wire diagram looks like pin 4 is Y/G but I need to make sure. Can anyone please confirm that pin 4 of the CDI connector is Y/G?
This is for a 2010GG CDI but per all the manuals I have seen it looks like the wire goes into pin 4 but there is a gap in the drawing and it does not show it go all the way to the connector. The reason I ask is the KTM harness does not have a wire in the pin 4 position but does in the pin 3 position. I am trying to confirm.
If you look where the wires go into the CDI plug, the end of each row is numbered. I think I may have found my answer via the KTM wire harnesses. The 4 stroke and 2 stroke harnesses are different even though they use the same plug. I believe the GG schematic is correct and the GR/Y wire will be in Pin 4.
