periclesgsilva
Hello guys. I have a problem with my GG. My battery is not receiving full charge. Measuring the stator the white wire are sendig less than yellow. So probably the charge coil are with some problem. For a quick alternative. Can i use the yellow to charge the battery? Until disassembly and send to repair? I mean change the plugs position before rectifier? The white are sendig less so for front light i presume Will be ok.
