Anyone put the Clarke tank on a 2011 yet? I'm wondering if it clears the new style carb and cable choke OK. I saw a note that said the carb on a 2010 couldn't be rotated to change jets. It looks like spark plug access will be much tighter. Also wondering if it clears the thermostat OK. The thermostat only sticks out a bit farther than the coil. I understand there is some issue with the mounting bracket vs the newer coil location. What actually holds the tank in place?
Anyone have a measurement (or pictures) on how far the tank sticks out past the radiators? (both sides with shrouds removed)
