I went with 10 tungsten carbide balls on my Rekluse clutches ('01 GasGas 300, '06 Gas Gas 300 & also my sons KX65) to get a firmer engage at low speed. It markedly reduces the low speed clutch slip for trail riding and works even better for trail riding. It still works very well, slipping when necessary.
The only time I get some GasGas clutch squeal with the Rekluse is corner case - clutch is hot, steep hill, too high of a gear and twisting hard on throttle. I find that if I manualy override the Rekluse clutch with the lever a bit it quiets down. I suspect it may be that it allows some more oil between the cltuch plates.
Mark, does the Barnett basket have the rubber damper blocks?
