Pulled the shock down today, time for a service and to play with some shims. While I was at it I pulled it right down and removed the compression adjuster. I had the intention of pulling it down too and seeing what shims were in the HSC part of the adjuster, but I can't figure out how to pull it apart.
It looks like the alloy end simply unscrews from the black anodized body, but there is no obvious way of doing.
Those in the know, is there a tool to do it or do you just use soft jaws in the vice to clamp the alloy section and use the nut on the anodized section to undo it?
