when i first overheated, there was no/very little fluid in the system. i dumped water in from my camel back. so the fluid you are seeing is from after it stopped/i refilled.
when i pulled the head the o-ring was cracked and broken/brittle. which probably happened from heat.
the centercase gasket was fine, and the base gasket was fine.
here's all i know. bike was running good, i warmed it up before the race. when i got to the first section, about 1/2 mile in, it was fine. i went a few hundred yards at wot, and my throttle cable stuck (or at least it felt like it was.) i reached down and quickly yanked on my throttle cable and it freed up. from that point on it started getting wonky. i went a few miles until it started wanting to stall out. had to fight it to keep it running.
after i refilled it on the side fo the trail, i did not run the bike. i did kick it over a few times though. hoping that magically a plug change would fix the problem and i could finish the section. so the fluid is all residual unheated coolant/water mix.
here's what i've been running through my head.
MAYBE i'm a dumbass and had an empty cooling system to begin with. MAYBE i FORGOT to refill it after i serviced it sometime in the last 2 months (bike sat idle for 2 months). i can't be sure but it's possible operator error is the problem. i'd LIKE to think it wasn't me, and i did fill the coolant (if i drain a system, i always leave the cap off...so this doesn't happen) but it is possible... it's the only logical explanation i have. because if the o-ring did fail when i was riding, it wouldn't have run well enough with a goofy mix of coolant/fuel. the outside of the cylinder is very bronze in color, which seems to me to be possibly baked on coolant/or overheat coloration. bike doesn't smell like cooked coolant. it wasn't puffing white smoke all over the place. so maybe it was me. i'd like to think it wasn't, but there's that thing in the back of my head saying, there was no coolant in there.
if it was pumping coolant into the combustion chamber, there's no way it would run for even a mile - that's a LOT of fluid to lose in a short time, that would all have to go through the crankcase/combustion chamber.. had to be my error. i have no other explanation. that would explain why the bike ran hot, why the inner oring is cracked/brittle. it would explain everything
99% of the time i do a pre-race look at the fluids etc. i did not this time - i had a nasty flu the day before, i didn't even think i would be able to race, i felt good enough that morning to race, but was still worried if i was too weak from the sick to even ride (i was so sick the night before that i slept 15 hours, and didn't eat anything after 2pm the day before...) - so my mind was elsewhere....i was still feeling woozy when i started the race.. i was afraid i'd be too weak to even kick the bike over. it was nasty.
