farmerj
Hi all,
I've been researching the possibilities for a Counterbalanced engine, and thought I'd post what I've found for others who might be interested. I must say I've never ridden one, but I'm interested in an engine that's smooth and more "trials-like" down low, and this seems like a fun project.
The bottom line as I see it, is that if you want a CB'ed 300cc engine get a '96-'98 engine and machine the cases to accept a 300 cylinder, or get an engine from a 300 Wild quad.
Thanks goes to Jim Cook for sharing his expertise and knowledge.
Feel free to contibute yours as well!
Originally Posted by farmerj
Hi Jim,
Don't know if you have time for questions!
I'd love to try a counterbalanced engine...Is it worth messing with?
Are there any used counterbalanced engines out there? Is it cheaper just to buy the whole bike?
I loved the Smackover website. Wish I had the "counterbalanced" threads from there! I remember one discussion about a company in California that would machine/match the cases & balance the crankshaft (?) and smooth out the newer engines.
Does that "ring a bell" to you? Does it work?
You are revered in GasGas land!
Thanks,
Jeff
Although the counterbalancer can be relatively easily added (with some machine work) to the '99-'00 engines), it's better to just get a '96-'98 (and early '99 model engines, which were actually left over '98 engines) and install one in a newer frame. (I'd suggest a '2005 or 2006 frame.)
To make the older counterbalanced engine fit into the newer frame, you will only need to have the water inlet on the head machined down to increase the clearance between head/water inlet and the fuel tank. (If you compare the height of the water inlet on the head of the new engines with the water inlet on the '98 engine's you will quickly see what I'm talking about. Everything else should fit just fine.
The true '99 engine is when the changes to the cylinder and head were put into production, and the counterbalancer was removed. The new cylinder and head can be used on the older cases, but some machine work would be necessary to fit the newer cylinder's skirt down into the older cases.
The '99 & '00 engines will take the counterbalancer, but will take a line sight boring job to get the bearing/seal faces true to the CB shaft.
The '01 year was when the changes to the crankshaft and crankshaft bearings were implemented. Some internal castings changes made the counterbalancer no longer an option to this engine.
'05 was when the cases were changed completely in the ignition area (where the counterbalancer rotated).
I think that Steve Marolda at Moto West was doing the engine balancing that you speak of. He does excellent work, but it really isn't needed (in terms of smoothness), with the counterbalancer installed.
Thanks for the kind words. Don't hesitate to contact me for any help I might be able to give. Feel free to share this information with anyone who might benefit from it.
Take care,
Jim
Jim,
That information is so helpful! It clarifies some mis-information I've seen out there. I may compile some of this and make a post on the forum for others who are interested in the CB engine.
You kind of "opened the floodgate" with your openness to help. Don't feel obligated to respond to all of these questions...
1. My understanding is that the all of the '96-'98 CB engines are 250s - no 300s made until '99. Is this true?
2. Have you ever heard of or ridden a CB'ed 300?
3. If a guy wanted a CB'ed 300, it looks like the options are:
a) Machine the cylinder skirt from a newer 300 engine and fit it to the '96-'98 cases.
b) Add a CB to a '99-'00 300 engine (with some machine work.)
c) Use an engine from a "Wild" 300 quad, as they are counterbalanced. Would this work? Is the ignition different than on the enduros?
Which is the best route?
4. Jim, at one point you said:
I absolutely love my 2006 300. It's the best bike that I've ever owned.
So is my desire to run a CB motor misplaced?
Thanks so much!
Jeff
Hi Jeff,
I'll address your questions by the number.
1.Correct. I know of a few '99 300 cylinders that were installed on the earlier cases to make counterbalanced 300s. That is where I learned that the cases need to be cut a bit to allow the larger skirts of the '99 cylinder to be used. (the skirt is larger in the '99 and later engines, which also have a slightly larger "water jacket".)
2. I have not ridden a c/b 300. However, I did have a '98 250 cylinder bored to fit a
Wiseco 14th oversize TRX250R piston (and then recoated with nikasil and honed to a precision fit) to make it a 274cc. I ran this engine for four more years. (I also had to shave the powervalve flapper for clearance.)
3.
a. No. Machine the hole in the cases to allow the '99 300cc cylinder skirt to enter.
b. Yes, but the work consists of a "line sight bore" of the place where the counterbalancer shaft, bearings, and seal will run and seat. It looks more simple than it is. (It looks like one would just have to drill a hole for the shaft, but this didn't result in the bearings being properly aligned; so a "case split line sight bore" from a machine shop is required for a good job.
c. It would work perfectly. If you didn't like the ignition, you can just swap with one off a bike. The basic part of the ignition is the same (it uses the smaller XC ignition with the 35w lighting coil, and also has the original '98- GasGas EC setup with the magnesium ignition cover with the Ducati style add-on extra 100w lighting setup. The extra lighting windings are bolted to the inside of the ignition cover and the rotating magnets are carried by a piece that is essentially an external flywheel weight on the outside of the flywheel), but the cdi is different for the quad engine. (As I said, the quad engine uses the same original ignition and lighting set-up as the '96-'98 EC engines (which first saw production in the '97 model bikes).
If you want a counterbalanced engine in your bike, then either use a quad engine, or install the older engine in a '05 or '06 chassis (or later)... (I'm not as familiar with the newer chassis, but love the geometry of '05 & '06 bikes.) The quad will be a 300 and, with no modifications, the older EC engines will be a 250cc. There is really no other difference.
4. Not at all. I just love my '06 300. But...I still want one with the counterbalanced engine, too...
Good Riding!
Jim
Hi Jim,
Thanks,
Jeff
Take care,
Jim
Jim,
Thanks so much!
Jeff
Hi Jeff,
3.
Good Riding!
Jim
