Hello all. I have an EC250 06 that I am replacing its piston. I read that a 86-96 CR250 piston is a direct replacement. So do I just put that on and I am good to go? Would it change some engine or performance characteristics? Also I read that the skirt on the CR piston is a bit different than the Gas Gas and that results in better low end.Is that true? Has anyone made the swap? I am asking because I found a Prox CR piston on ebay that is a lot cheaper than a Vertex for the Gas Gas and I believe that both brands are very high quality so I wouldnt mind saving a few euros to go to some other upgrade.
