Cracked frame 2012 ec250
Daniel2801
Has any one experienced cracks in the frame at the lower engine mount?
Bike is a 2012 ec250 with approx. 160 hours
Checked my 2013 with 166hrs. Couldn't see any damage.
I have noticed that the upper mounts have slacked themselves off once or twice during this time though.
Thanks. I cant see any reason why it would crack here.
My upper mount was loose for some time. Maybe this had something to do with it.
Sent from my SM-G920I using Tapatalk
If you knew it was loose , why didn't you tighten it down? Vibration will travel fyi
I didnt realise as the nut was topped out on the bolt so it seemed tight. I had to space it out with a washer when i finally found the issue
Yes. I have a 2012 EC250 and cracked the right side lower frame close to engine mount. Not sure how as Arizona terrain can be nasty, but I also Moto with it. Pulled the motor and a good weld with no problems. From your picture it looks as though it was in the exact same place? Mine was the right side.
I ended up getting drilling holes into the frame where the cracks stop at an attempt to stop future cracks. I then had it tig welded.
