Cranck seals dimensions,stator side.
adriano.ro
what size( no oem code) is left cranck seal? When I take of the stator plate I saw a very thin layer of oil coming from seal. Can this make the engine to work improperly? Can I change it from outside?
Sorry for my bad english :)
Just a quick question regarding crankcase and sealing: Is there supposed to be a O-ring on the inside of the crank-case seals? This is on the clutch side.
Lip seals normally have a light spring around the outside of the rubber lip. I have seen ones where the spring was damaged and someone replaced it with a lighty stretched oring. This would not be a long term solution because it is difficult to match the spring tension. Maybe someone couldn't get a new seal and was trying to get a bit more life out of the existing seal.
The parts list shows an oring in that area if you are not specifically referring to the seal itself.
Yes, there is an O-ring between the bearing and the seal on the right hand side of the crank shaft.
No O-ring on the left hand (ignition) side.
Affirmative.
Similar setup to the counter shaft where the o-ring goes on the crank shaft, then the bushing, then the nut.
