hey so ive just pressed the crank pin out from my crank after a big end bearing failure (part of the needle roller cage made a key way in my piston). anyway im after the distance between the two sides of the cranks so i can use slip gauges when pressing the new pin in.. failing that im after the amount of float the rod has between the side of the crank and the white metal coated thrust washers? is it possibe to use feeler gauges when pressing the new pin in to set the float? also i am thinking that liquid nitrogen is an option to seat one side of the crank pin as it would make it that little bit easier to press.. i am planning on turning a bit of bar to use as a dowel to align the two parts of the crank roughly before pressing then trueing.. the dimensions from one side to the other are 150 microns difference the fly wheel side measures 22.20mm and the other side measures 22.05 there is no problem with turning a stepped dowel but is it worth using the dowel holes or can they effectively be a way out? (are the crank sides machined/drilled together making them true?) also does around 12 tonne sound about right as that is what it hit before the dowel moved.. are the cranks frozen when made or just pressed.. if you have any of the information above please share as it would be extremely appreciated thanks luke
