Trying to get a 2003 300 jetted properly.The 2003 owners manual says base line settings are185 main,35 pilot and a n1ec needle clip in the middle.We have a correction factor of 0.98
The carb had a 180 main,40 pilot and a n1ef needle.
I think the 180 is a decent main given the correction.
The bike runs a little rich right at the bottom but starts well.If It will run on the 40 pilot Id like to have the torque and the easy starting a richer pilot gives you.
I think needle and air screw adjustment is probably our biggest issue.I took the n1ef.needle out and swapped it for the n1ec needle I had in another carb.
The n1ec is leaner then the n1ef.correct?
The bike would only run decent when the n1ef.needle was all the way down clip up in the 5th notch.
This carb Isnt easy getting in and out so if anybody has some good numbers or some ideas.that would be great.Bike is mostly ridden in the Trask spring and fall.Mild temps elevation between 800-2200 ft.
Bike is tip top with good compression, packed silencer, clean filter running redline at 50-1 ish.
Bike runs ok but it a 300 so it runs ok when it really Isnt running ok if you know what I mean.But it doesnt bark or have instantaneous throttle response.Its not really that happy all way around.
