Its me again. I was re---- and fucking hammered the cylinder in. In result, it got some small scratches. You can feel them with your nails, and one is a bit deep. They are about 1mm high and 5mm wide. Its around 3 of them. What do I need to do? Can I still use it? How does it effect the performence and hardware
As Ive bought one more gasgas with its engine apart, I took the cylinder from that one and the piston, but that will in return get the damaged cylinder.
I can send a picture soon if its needed.
