Gmp ,
l have a 05 ec 250 ,it had the dual cdi on it but no switch , l put a switch on it about a year ago , the sunny mode feels like the motor has been leaned off a bit , it is a fair bit crisper and has a slight but noticable crack to it , l like using this setting on open courses when its really muddy as the rear spins up quicker and seems to clear the rear wheel and grip , the rain setting mode ( handbag mode ) is pretty helpful when going gets tricky , slippy uphill climbs are a little better , on the whole the effect of the switch is quite suttle , worth having if you have the dual cdi fitted already , just for the record l also tried the bigger power valve cover but l found it had too much bottom end and took it off after one race , hope this of some help
...has anyone heard of that switch being retrofitted on another brand of bike. i have a customer asking if it'll work on a KTM. i explained to him that the switch and CDI are most likely "linked" togeather and won't work on another brand.
it seems to me the duel "map" is inherent in the Gas-Gas CDI. so how would the switch work on another manufacturers CDI?
i just learned that the KTM does have the dual map CDI. i didn't realize it's the same unit. thanks for the help. now i'm off to find the switches. my guy want the "hi-zoot" Gas-Gas switch.Both companies use the same Kokusan cdi unit.
Those that have the newer 250s with the dual map CDI, could you please desribe the difference in feel between the two maps? Thanks.
Its sure been dead around here lately.
Gmp ,
Hi!
My MC had the cdi in the airbox and if you check the cdi you would see two simple (red-black or black-white I think) wires connected together. If you just disconnect them you get the "cloudy" mode.
If my MC was a 6-speed like yours I wouldn't change it. Just a 14oz weight... With the 4-speed there wasn't any torque feeling down low and it needed a lot of clutching in technical parts with a lot of load on the engine (I felt sad hearing the clutch crying...). The mid and top power IS amazing with good overrev. A friend of mine with a 4-speed 525 SX was really impressed with the MC in a sand MX track.
Leon
