KTMAndy
Gmp ,
l have a 05 ec 250 ,it had the dual cdi on it but no switch , l put a switch on it about a year ago , the sunny modefeels like the motor has been leaned off a bit , it is a fair bit crisper and has a slight but noticable crack to it , l like using this setting on open courses when its really muddy as the rear spins up quicker and seems to clear the rear wheel and grip , the rain setting mode ( handbag mode ) is pretty helpful when going gets tricky , slippy uphill climbs are a little better , on the whole the effect of the switch is quite suttle , worth having if you have the dual cdi fitted already , just for the record l also tried the bigger power valve cover but l found it had too much bottom end and took it off after one race
, hope this of some help
Finally re-found this post! I read this with interest the first day I joined the forum, I believe I have the dual map CDI, under the seat, black wire, looped back into an orange wire on a single connector.
So next question, where do I get the switch from and how do I wire it up? What does it switch between, I,e, black wire goes to switch, and returns to??? And which wire is which?
Look forward to reading the answer, I'd like to try the dual map!
