Porkyblader
Hello all, I own a 06 300 ec which up untill today was running great,took the bike out today & after around 30 mins an engine rattle developed which was bad enough but when the throttle was cracked open ( bad idea I know ) the engine revs stayed low & flat no matter if the throttle was fully open.
I have removed the power valve cover but nothing loose,damaged or slack & when you move the arm by hand the valve does open & return to closed the position when released..does this operation need to be checked with the engine running ??? lastly the compression is still good.
Any help or advice is appreciated.
