Zman
We had an EC200 that was in need of more power. I called up Eric Gorr who built the 327 big bore kit for my XC300 and I asked him if he could super-size the 200. He told me he would check it out so I dropped off a spare EC200 engine with him.
I always heard you could not do a big bore kit for the GG 200 engines so I was super excited when he told me he had it finished. Eric came up with a really cool kit that increases the stock bore from 62.5mm to 68mm so the new engine displacement is 236cc.
The cylinder and head turned out great and the install was straight forward. I used the 0.005? thin base gasket shim and the 0.011 gasket and the squish came out to 0.045? or 1.17mm which should work well with 93 octane fuel.
The bike has more compression than stock. It kicks over with a bit more effort than a stock 200 but it fires right up. The jetting was pretty close from before, but I needed to lower the idle speed a turn or two and richen the idle mixture slightly because it was jetted for 70F riding not the present 25F and snow.
I do not have a good place near my home to really ride the bike but from the 20 minutes of riding around the neighborhood it feels considerably more powerful than before. It has very good throttle response down low and still revs nicely. I really like that the bike kept the GG linear power deliver and that there was no added vibration. We are headed to TN for our spring break trip at the end of the month so I will have more details on how it works after the trip. This was his first kit for the GG 200 so I am testing it out the prototype and I will be giving him feedback after this trip. http://www.eric-gorr.com/
Here is a photo of an old worn out 200 piston next to the big bore piston. The new piston is 5.5mm bigger than a stock 200 piston and it is even larger than a stock 250 piston.
