R Rampart New member May 31, 2017 #1 Can someone tell - how many volts and amperes makes ec300 generator?
N Neil E. Active member May 31, 2017 #2 2K3 = 70W maximum Voltage depends on your regulator (or rectifier if estart), assume about 14V
R Rampart New member May 31, 2017 #3 http://www.gasgasrider.org/forum/showthread.php?t=164 here says near 85W, so with 14 wolts it's near 6A, and if 12 wolts - 7A. ok. My fan is 12 wolt 3.8A - will it survive direct install?
N Neil E. Active member Jun 1, 2017 #4 http://www.gasgasrider.org/forum/showpost.php?p=177164&postcount=13 Direct install on an estart bike can run your battery down. Particularily important in slow bushwacking situations. A kickstart only bike will need the rectifier (as previously recommended).
R Rampart New member Jun 1, 2017 #5 I don't have estart or a battery Here i asking output characteristics of generator, so i will understand which rectifier i need.
pscook Platinum Level Site Supporter Jun 2, 2017 #6 Rampart said: I don't have estart or a battery Here i asking output characteristics of generator, so i will understand which rectifier i need. Click to expand... I'm not the best with electrical, but shouldn't you get the size of rectifier that the fan draws? It won't matter if it's too big as the fan won't draw any more than it needs to run, right?
N Neil E. Active member Jun 2, 2017 #7 Use the rectifier that comes with the fan kit. That's all you need.
