EC300 vs 250f questions
forgiven
I have a 2010 EC300. I really like it. I am looking for a backup bike and have come across a 2010 250F (gasgas)
The whole 2 vs. 4 stroke thing withstanding...what would be the riding impression differences between them. I am assuming the 250f will be slightly heavier but should handle similarly. My son has a 2006 Yz250F with a flywheel weight and I assume power delivery should be similar except maybe a bit more on the bottom and a little less on top.
I am a woods rider. I would really like to hear from guys who have ridden both.
Another question on the 250f. My wife rides a 230f now and I try and set up her bikes to NOT wheelie as she will sit on her rear going up hills and I would like to see her at the top. How light does the front end get on these, and what could I do to counteract that?
I KNOW they are seemingly different in nature. I am just looking for someone who has ridden them both and could comment. I know there are advantages each way.
Thanks
From what I've noticed, the 300 has smooth power all around, whereas the 250f is still very smooth, but doesn't have quite the pull that the 300 does on the topend. Pipe and sprockets could easily open it up if need be.
You're comparison to the YZ is pretty accurate. Great lowend power and very smooth on the GasGas vs a harder hitting power on the YZ (great for mx, maybe not so much in the rocks and trees).
imo I feel like all of the two strokes from 125-300 are more nimble than the 250f, but the added weight isn't as big of factor as you might think, so long as you're not spending all day picking it up off the ground.
I just sold my EC300 and own a EC250.
I owned a Yamaha WR250f ('07) for a year and rode it exclusively as my woods bike.
The biggest factor is terrain and ability level in when considering a 250f. For a slow A or B rider, the 250f is a spectacular bike in the tight woods. Most poo-poo them as a beginners bike or girls bike, but they are truly great in the woods. We have a local A expert who is on the podium regularly with his WR250f.
The weight is really not that noticeable IMO coming off of a 250/300 2-stroke. If you were on a 125-200 I would say that the weight then is more of a factor.
The 250f is no powerhouse (about 30-35 hp depending on mods), that needs to be stated right up front. It does not come close to the power of a 250/300 2-stroke. But, it simply puts the power to the ground very well. Not wheel spin, no fuss, just puts the power to the rear wheel nicely. It does not have the quick snap of a 2-stroke, so sometimes an unexpected obstacle where you need to loft the front end, can be an issue. It takes a bit more planning to do that as opposed to the quicker reving/responding 300.
I found the WR250f to be so EASY to ride. I am a "B" rider, mostly tight woods and weigh about 225lbs. Believe it or not, I was faster on the little WR than any of my 2-strokes. I felt it handled very well in the rocks and roots in the tight woods with its nice soft suspension. It can be railed in the corners and I just felt it was perfectly suited for tight woods riding. I rode it with tons of confidence and loved ripping on the bike. Where you usually have to hold a 250/300 2-stroke back, you can push the 250f.
Now, when things open up 3rd gear on up, the WR starts to loose its luster. The lack of snappy power and softer suspension begin to become a factor as speeds go up.
I ride a bit in terrain where you can rip in 3rd-5th gear. I love the 250/300 2-stroke in this terrain. The better suspension and more aggressive power delivery of the Gasgas EC300 are awesome in this terrain.
There has been a bit of a movement toward smaller cc bikes here in the NW. With our tight woods, many are riding 250f thumpers and 125-200cc 2-strokes. Lighter, easier to ride longer, fun to push hard, handle awesome.
I've considered going back to a 250f or 200 2-stroke for those very reasons. But, a 250/300 is very versitile and can tackle a broader spectrum of terrain.
Hope this helps.
I am sure the geometry is a little different but how bout if my wife is riding up steepish hills sitting down...would it wheelie pretty easy or still take some effort?
I own a WR250F and also agree with all above.
On the bottom end it will still feel like the 300. As the revs climb it will pull more, but not like the 300. I can still loft a wheel on my WR250F up a hill. You can gear it tall or have her ride a gear high. Best approach would be to educate and explain body position. Isn't learning what riding bikes is all about.
My wife is almost 50...I just want her to have fun as safe as possible. If we were both younger I would say let her learn her lessons...but that isn't the case.
The gasgas has a slightly longer wheelbase than the wr250f, about 10mm. So it might be slightly less prone to wheelstanding.
I think rider coaching is very good for increasing confidence and safety, which results in less stress and more fun, which is what its all about isnt it?
Is her 230F lacking in some area? Or you just love GG so much you want to add another to the stable :p (No one here would blame you; biased crowd)
Perhaps make her a deal that if she can work on improving her position then she can get a new ride! Its win win win for everyone.
I wasn't suggesting for her to go balls out and loop it to learn her lesson. No one should have to learn that way. IMO getting the basics down on a low powered poorly suspended, weak braking bike is the best way to progress and will make you apreciate the upgrades even more!
FWW the stock WR250F came with a throttle stop that limited the bikes to around 3/4 instead of WOT! Not sure if GG runs the same setup but it wouldn't be hard to implement and really makes them mild.
I think that bike would be good, as long as she could pick it up. Its within a couple pounds of a 250/300. I never rode the GG, but the Yamaha is soft off the bottom compared to the 250/300 GG, and easy to ride as long as there are no steep hills without runs. They work very well in slick conditions, just less excess power to manage. I've spent a little time on an '07 WR250F and liked it, although it turned slow IMO. If the GG250F was coming here for 2012, with the new forks and frame at a competive price, I might have gone that way myself, but kept the 2-stroke. With a battery and estart, its easy to add a rad fan if she can't make the speed to cool it. Yamaha's are pretty good though, and with the big GG rads and waterless coolant it should be no problem. Parts are on every corner too. Just don't blow it up! $$$:eek: Honestly though, the woods ridden Yamaha 250Fs I've been around are great and reliable for years.
I have a large 12 yr old son who will need a full size bike before the end of this year. My 250 will be too much, but a 200 motor in the frame or one of these 250Fs might be perfect.
Always sharing what is going on in my head is dicey so...
1. I need a back up bike, but estart with the similar handling, and my 300 has been much more finicky than my previous 300...so it could replace my main bike. Hot cams exhaust and intake, with a mega bomb header, and a 290 kit would make it one hell of a bike down low...which is mostly what I do.
2. My son who is 14 doesn't like the Suzuki GS500F or crotch rockets in general so for a bike when he is 16 to go to school he said he will want a motard looking bike. So if I get it could be my back up for a couple years then his school motard with some street tires...or even dual sports.
3. My wife has a 230 with a CR250 front end with a works rear. Not a bad bike but not a GG 250 to be sure would have more power and be smoother and more balanced a bike. Anything I can do to support her helps me in the long run.
4. Possibly after 2 years as my back up, my wife moves to it, my 10 year old would be ready for the 230 with good suspension...my 300 becomes my backup bike and I get one of the 2nd year direct injected bikes (2 stroke)
At this point I don't see how I can't pick up the 250...just too many good options there.
Didn't even consider the fact that I could swear up and down I had the 250f last year and never had a 300 and that the riding club is losing their collective minds.
Well it sounds like its sold :) You've justified why you want one on more than one level so if the funds are ready find someone to sell you one and then delight us with the ride report!
Jakobi-pretty much, I am a fair weather rider so...
Alpine-The difference in price to new is too big unfortunately plus it will look almost identical to my current bike which I think is awesome looking, and it will match all my gear...I know...I know...
I am not...although it is a nice bike and I was teetering on that one. I believe he has it set up almost exactly how I would like it too. Someone should jump on that.
The Gas Gas 250F at Hall's is sold. It was sold Tuesday. Steve has yet to take it off their web site. Thanks to all that showed interest!!!
