Jakobi
The other day I noticed my 2010 EC250/300 kept resetting the trip meter and would read weird at times. Its got the trailtech vapour and in the past its usually indicated a flat battery. Replaced the battery prior to todays ride and no good. Its still playing up. Further to that a couple blokes who watched me climb up a hill towards them said my headlight keeps coming on and off. Confirmed with the mrs that she noticed it the other day when I was joy riding around the yard but thought it was normal Gotta love em!
Anyway. I have noticed the speedo sender cable is a bit worn on the outer cover and I have a new one here to replace. The magnet on the disk looks like its been chipped in the center which maybe might give the strange readings of the km/h going up and down irratically. I don't have a new one to test but will start looking to see if I can get one. Even then it doesn't make sense about the headlight. Considering both are running from power via the stator I guess the first point to check is the connection under the tank. How much output is expected from a 2k3, and do these bikes run a regulator at all?? From what I gather it feels like its undervolting as the revs fall and spiking up with throttle. I'll have to do a night ride to test the theory on the headlight though.
Any help will be most appreciated. Cheers in advance!
