jaysktms
Well , when I shut the throttle off I get a buzz. I know I check all the usually stuff. Heres the run down of what I checked, I installed EE Rad guards and then removed them still there. Removed the plastic skid plate, still there. Placed foot on pipe the buzzing drop a bit, but over all still there. I did notice on the cylinder head the top mounting hole is not used. On the older gasser this was mounted to the front frame, but dont see any holes. Does the 12/13 not use the upper cylinder mount anymore. Any input I am will to try.
