Engine rear mounts are loose
stian
Bushing engine mount due to worn mounts
Hi.
- Aluminium top mounts was broken when I bought it, replaced it, but rear engine mount was quite badly worn out. This also includes damage/wear on the side of the mount, so i am wondering about measurments on the engine block.
As stated in picture, the measurment from A, to B at the rear engine mount.
- Bolt is 17mm
- My left hole is 19,5mm wide, 18mm high.
- Right hole is 18mm x ca 18mm.
Questions:
- Tolerances bolt against engine mount hole? 0,4-0,6mm?
- Measurment from hole to outer other casting? So i know where center is.
What does other people do with this?
