After picking up my EC300E 2011, I could see that dust would get in the bottom drain hole of the stator and stick in the starter grease - just like the KTM's do.
So I washed the grease out of the starter gears, sealed up the drain hole with devcon and added 100mm of oil. Then fitted a brass tube in the MX stator grommet and breather hose.
During the first ride up the road I discovered that the hole in the bottom of the engine case is not just for holding the cases in the factory when they machine them. It is also a stator side drain hole. So I blocked that up too.
The GasGas SM14 starter runs great and out performs the SM16 KTM/Berg starter that my riding mate had today.
I will post pics when I am back at work.
