Any body know were i can get a flasher relay for the 2011 ec , mine just stop working, it a 12 Volts 20W AC ( Leonelli), i can only found the DC in the local store.
If GoFasters can not source one for you. You should
try a scooter dealer. They use Leonellli electronics too. http://www.gasgasrider.org/forum/showthread.php?t=2983&highlight=leonelli
Is this what you are looking for? The one on the right side of
my post.
This is how I converted my AC Leonelli flasher to a DC Auto flasher
after doing the 2K3 floating ground modification. I had to swap
a couple of the wires in the connector.
I used to have a couple of these sitting around, but, gave them
away not too long ago to a list member.
Best of luck. Don't give up.
Jeff
I have been using the flasher relay like candy, they do not last on the 2011 model. On my old bike the 2006 i never had any problem. my question is can i use a 2006 flasher relay in to the 2011 model.
My 2010 uses the leonelli and died really quickly too. My dealer replaced it under warranty but i have just thrown it in a box for when i need it. Took all the flashers off mine.
