Flywheel and stator help
theexception_03
Hey ppls, i know this is probably really easy but....
I don't know how to get to the flywheel and stator. I haven't done it before and i am not sure how to access them.
I did a search for any threads about this but I couldn't find anything.
Any help with pictures would be great!!
Thanks
plastic left side cover on end of crank. 4 bolts. you're gonna need an impact to get the flywheel nut off, and a flywheel puller - can't remember what size.
Pretty sure its a 27mm x 1.0mm thread for the fly wheel puller. You can also use a bit of starter cable down the spark plug hole, a special plug engine stop, or a holder on the flywheel to get the nut undone.
