footrest pins
imsimon
Hello, Ive managed to break my RHS footrest pin, im in the UK and I cant find anywhere online that stock them I know I can get them from motorcrosscenter but I need them quick for a ride in a couple of days time, also itd be $15 postage for a $6 item so question is - anyone in uk know where I can get some, I see somepeople say they've used Yamaha ones? I guess wr and yz? will either be a direct fit, any other option available to me? maybe just a nut and bolt even as a temp fix, im not the cleverest with sizes so if bolt is an option what size nut and bolt would I need?
many thanks
Can you take out the pin from the other side or just take the foot peg with you to the hardware store and see which one will fit.
many thanks
Yamaha YZ250 two stroke is exact same pin.
thank you! Ive managed to order some direct from gasgasuk as they ended up costing same as others and I can get them next day
thanks again
si
