Frames 2012 and 2013
jaysktms
On the 2012 there are slots is the side frame, you don't see them on the 2013 are they just covered up with the frame protectors.
Yep. Note of caution - the leading edge of the frame guard is very pointy at the top. Like pierce your flesh pointy.
What list?
My Importer? He won't even get me spareparts:mad:..
Wish I was in the US.. or just anywhere else than here in Denmark..
I need to mail order all my spares from UK, Germany or Spain..
And I can't find the part numbers for the '13 frame protectors..
Yep. Note of caution - the leading edge of the frame guard is very pointy at the top. Like piece your flesh pointy.
Sounds like this is spoken from experience?
Just a side note, when you get here and we go ride I am "Off Duty"! J/K I will stablize you long enough for you to see the outrageous helicopter bill for flying you out!!!! :eek:
On mine, the kick start lever gets caught on either the frame guard or the zip tie holding it on and doesn't let it spring back. Not a big drama, but if you are kick start only, you might do a test before you take it to the trail. If they interact, sandpaper or lightly dremel the guard.
Thank you..
Can I shop parts directly from blm? they have no shop on their site..
Motocrosscentre have them in stock now , i know as he emailed me to let me know last week , i managed to get some from gas gas uk first though .
Like phoenix says the kickstart sometimes hangs up on the plastic though.
Thanks, I'll try emailing them.
The kickstarter hanging up issue? The original starter already broke in half:mad:
Would a YZ starter give less or more clearance than the stock?
The kickstarter broke in half????????????? Why???????? If my new Gasser does any weird crap it will be for sale and back on a Husky I will go.... I have had around 5 older gassers and NEVER had a kicker that broke?????? What happened???
I've had five Gassers 2010 and newer and never broken a lever either. Even if I did, I'd surely go for a YZ lever instead of trying to kick over that twisted piece on the 250/300 WRs.
I don't know what happend:confused:
Actually it's not my bike, I can't afford a '12:((I only have two '06, what if I put them together, does that make a '12?:D)
At first I was thinking that the owner just slap kicked it really hard, I never broke a kick lever myself, on a 2stroke that is, i broke one on my Honda 250f(it was a bitch to start)
But after seeing the broken lever I'm suspecting a cast fault, It's snapped of right after the last bend, right where the "boot grip pattern" starts..
And since I've heard of a few '12's out there that broke starters within the first few runs, maybe there has been a bad production lot of starters in 2012.?
On my 06 200 the clamp around the splined shaft broke. I replaced the complete kickstart lever with one of the new design. I expect the new kick start lever to last a long as the rest of the bike. I had to grind the inner diameter of the plastic frameguard somewhat to be sure that the lever returns to th upright position every time I kick it.
Sent from my OMNIA7 using Board Express
