I am at a loss. I bought an 2001 EC 250 a few months ago and it has not run well at all. (previous thread http://www.gasgasrider.org/forum/showthread.php?t=1912)
Initial symptoms were:
1. Horrible bog off the bottom
2. Only came up on pipe at WOT after feathering the clutch a lot.
3. Smoking uncontrollably
4. Fouling plugs
I checked the jetting and found a 172 Main. 38 Pilot and Stock needle. It seemed to be really rich off the bottom. I also noticed that I was oil fouling the plug.
Repairs/Adjustments made.
1. LTR Needle in middle clip
2. Replaced Right Side crankcase seal
3. Cleaned the Carb
4. Checked float level
5. Replaced Reeds with Boyesen Carbon Fiber reeds
6. Repacked silencer
7. New plug(s)
8. New Air Filter
The bike still does not run well. After all of these repairs, I tool the bike out and it still seems to be running poorly. The symptoms were the same. (example: from a dead stop, 1st gear start, I roll on the throttle and the bike seems to four stroke. Kind of like pulling the choke when the bike is already warm. If I feather the clutch wile holding WOT the bike pulls like crazy and will loft the front end through 4th gear). This leads me to think that it might be rich off of the pilot, but a 38 seems small already.)
Update"
I went to start the bike yesterday for a pre-ride warm-up and it fould a plug immediately. I am thinking that the power valve may be stuck open. Does anyone else have any ideas? Could this be an electrical issue? Please help!
4. Fouling plugs
3. Cleaned the Carb
7. New plug(s)
8. New Air Filter
Update"
