Hi,
Thank you!!! No, I did not check yet. The bike started to act like I've said suddenly, so I firtsly think that the prolem can be of electrical nature. Also, after some reading in this forum I've found out, that many things can cause problems with starting, thus, I want to check what I can do by myself (check connections, etc.). BTW, could you possibly now: I've changed the spark plug to the new one (NGK CR8E) and after ~ 5 hour of riding I've foud out, that it is black. May this be a situation causing problems with starting? Should I install the new spark plug, like CR9E. As the manual says:
"To find the correct heat grade spark plug is being used, take it out
and examine the insulation around the electrode. If the ceramic is
light brown, the spark plug is correctly matched to engine temperature.
If the ceramic is white, the plug should be replaced with the next
coldest plug. If the ceramic is black, the plug should be replaced
with the next hottest plug."
